Monitor keeps blacking out
30 Mar 2010
Glasgow
My montior has recently started to go into Standby mode whilst i'm gaming. My base unit it is still powered up
Once the monitor has went into stand by it wont go back on unless i reboot the system.
I'm sure its to do with insufficient power but i'm hoping someone will be able to shed some more light on this
AMD Phenom X4 955
Asus Formula 3 motherboard
4GB DDR3 patriot Sector 5 viper 2 ram
HD 5750 1024MB GDDR5
640GB western Digital HDD
Windows 7 ultimate 32bit
Cheers,
Are any of the components overclocked & does this happen in all games.
The gpu software upto date.
nope everything is as it came
only happens in assassins creed 2 at full graphics
hasnt happened on anyother game or even when i'm working with multiple virtual machines and anything else that requires my system to be pushed in anyway
forgot to mention PSU is 600 watts
Hmm, I would suspect it may be the game, are there any patches available for the game.
If you were not getting enough power I would suspect you will get stability problems in most applications.
Download Prime 95 and 3d win mark 2006 or fur mark which can stress test the cpu and gpu and check for stability.
What make is the PSU.
