- 30 Aug 2007
Hi all
I’m looking to replace my long-serving 17” crt screen, so I have been looking at the variety of LCD screens that are available and have reached a bit of an impasse.
I generally use my machine for graphics work (photo editing, 3D graphics, etc), but would also want to run games. So decent colour rendition would be important to me (but not £1200-pro-spec-monitor important)
I had been looking through the reviews of the Samsung SM226BW, it seems to be well regarded, offering fast response times and respectable colour display.
So I went to have a quick look at them in the local computer store to check before ordering online
The screen looked ok, not as ‘bright’ as the LG screens next to it, but the colour looked ok.
This was before I looked at the whole ‘panel lottery’ issue - http://www.behardware.com/articles/667-1/samsung-226bw-a-and-s-series-the-verdict.html
So I cannot find out what ‘type’ of SM226BW I will be getting before it arrives ? That does seem slightly crazy
Even a high-street store would not be exactly understanding of you asking to connect up a bunch of their stock while you sift through the serial numbers
So, I guess im asking if its worth it ?
Would a different manufacturer offer a better chance of a decent screen ?
I’m seeing good things about the Dell Ultrasharp 2007WFP, but at 20”-widescreen would that not have a smaller screen height than my old 17”crt ? (and that also has a 16ms response time)
Finally, I overheard a store employee mention a replacement to the SM226BW, im guessing that is the SM226CW ?
So what are my chances of getting a ‘samsung’ Samsung SM226CW ? better than the 226BW ? Seems like a crazy question to have to ask
Any input is cheerfully appreciated.
My Budget is £200-300.
Thanks.
Thanks.
