Monitor or CPU upgrade etc
31 Oct 2007
Gods County(Allegedly)
Have approx £300 to spend and am torn between either :-
1) upgrading 20" Samsung 205 bw to samsung 24" 245B or
2) Changing Opteron 185 for a Quad core Intel/amd and new motherboard and ram .
Graphics are 9800GTX
Would appreciate members views
What do you use your PC for mainly? I think I'd personally be going with the monitor upgrade as most likely to make a difference but then I'm less of a gamer at present than I used to be.
I would get the monitor first since they dont drop that much in prices.
Then maybe pick the rest later when maybe new parts come out or the other gets cheaper.
The monitor is not something you're upgrading too often so a nice 24-26" will probably stay with you for the next 3years or so while u're most likely to get 2-3 CPU/Mobo/ram/gpu upgrades in that time :).
Thanks for replies - have decided to go with new monitor but am having second thoughts as to which(See new thread in monitor section):)
