Monitor
Permabanned
2 Apr 2013
North West
Hey lads, a friend wants a new monitor here and has £400 to spend. He currently has a Benq XL2420T and a 980ti, so is considering moving to 1440p. What is the best he can get for that money?
4K isn't an option, 60 hertz just isn't enough for gaming.
Of course it is, a 60Hz 4K screen with a low response time are actually brilliant for gaming, i had mine playing all the latest FPS games with no problems at all. He would benefit going with a G-sync monitor though it's not that important.
For £400 or under you have quite a lot of choice if you want to stick with 1080, though i'd definitely go higher than 1080, 1440 or 4K is where my money would go.
https://www.overclockers.co.uk/showproduct.php?prodid=MO-071-AS&groupid=17&catid=1895
https://www.overclockers.co.uk/showproduct.php?prodid=MO-119-IY&tool=3
Have tried 4k at 60hertz and hated it, I couldn't play on less than 120/144 anymore myself. Thanks for the options I will let him know mate.
That would depend if he had tried 120+Hz, I have a 144hz monitor and 60hz is disgusting.
