- 4 Jun 2010
No linking competitors, that will be some awesome build by the way, maybe make a build log?
what I will need is help when built how to safely maximise the over clock!
other than the coil whine? complaints what's wrong with the ax1200? jonhyguru gave it almost unanimous high marks across the board.
stulid could you answer the question regarding the seasonic p1kw vs the xfx 1kw? I was editing it into my last reply as you were replying to it.
i have been reading up on the sesonic 1000 one and it sounds perfect.
what are the limitations of a 1000 wat psu? in regards to gpus? and cpu I probebly wont go to tri sli and will keep 2 580gtx and over clocked 3960
have i got good margins on this 1000 wat psu
also its on pre order, so hope it comes in on time 25/11/11. Im on holiday for a week so cant build till then
what about the warranty issue? how are xfx with rmas should you need to in say a couple of years?
I have 6yr old seasonic s12 600w still going strong(in a pc downstairs that my 4yr old niece uses, sister and her husband also use it, built it with spare parts I had) and a ~3 1/2yr old corsair hx620(in my current pc), not had any issues with either of the two thus far. have a coolermaster real power m850 but that has spent most of the past 4yrs 'gathering dust' as the pc I used it in wouldn't work properly and I never spent too mcub time trying to sort it out, will be using the cm psu in the new i2500k pc once I get the motherboard sorted as I'm going 6950 xfire but thinking about trifire in the future so looking at 1kw psu.
