Bit bizzare if true, the enthusiast platform hasn't had a quad for a while and mixing 'skylake' and ''kabylake' in simultaneous launch is a bit of a first
Only the IPC difference with KBL is already faster than what AMD will be offering, so the FX9370 comparison is slightly moot.
That's before even considering any further process refinement that might go into KBL-X.
Time will tell, numbers don't lie.
Wait, apart from core difference, what's the difference between Sky and Kaby X? Just the process (14nm vs 14nm+)? Most of normal Kabylake's improvements was on the IGP, especially the media decoder.
Cores and PCI-E Lanes i suspect, a long with IPC, IMC etc
Wait, apart from core count difference, what's the difference between Sky and Kaby X? Just the process (14nm vs 14nm+)? Most of normal Kabylake's improvements was on the IGP, especially the media decoder.
KBL has 0% IPC increase over SKL, they use exactly the same cores.
KBL is still obviously superior to SKL, since it uses an improved 14nm'+' process, allowing it to clock higher. AVX offset is also a great feature. Only the IGPU was actually changed, allowing 4k protected content to be played etc.
As for Zen, it's unreleased, may be closer to SKL/KBL IPC than we think![]()
KBL cores are identical to SKL cores.
How do you know that? :/ we haven't seen either yet.
Surely we don't know the IPC with what Ryzen is doing.
Surely we don't know the IPC with what Ryzen is doing. Other than AMD stated they wanted 40% greater than their previous line of CPU's and they stated they are already beating that figure back in mid December so with that what can we expect it to be upon release.
