More speed possible?
27 Oct 2004
Stoke on Trent
just been regraded to Pipex Max service, currently connected at 6.8Mbps with these stats :
so will they push the line further?
also is the bits per frame related to the speed? the 273/1843 just seems out of place :o
You generally need 6dB of SNR every MB you increase.
So for example, going from 6 -> 7 would need 6dB, and seeing as you are on 6.6dB then I'd say it's not likely you'd get much more than you already got.
looks like your using the same software as some pci adsl modem i had, it was really bad compared to any router i've had since has given me better line stats and higher sync speeds
could anyone recommend a good router actually?
ive been meaning to get one for awhile so i dont need the PC to be turned on to use xbox live
edit : its just synced up to the line at 7.6mbps after switching to my speedtouch 330 modem
