Yes, it is even better than locking your mother-in-law in it![]()
Wouldnt 10k worth of usb block erupters be any better?
I entered wndsr's cellar on Sunday as I was in the neighbourhood. The heat OMG the heat! We stayed down there for circa ten mins chatting about the rigs, how the mining is going and what else can be done to bring down ambient. After the ten minutes we had to leave the room though as it was just so oppressive!
There are 6 rigs all running 4 280x's. He's had problems with PSU's going pop and whilst the ambient is stupidly hot the GPUs are all running at "sensible" temps.
Wndsr, wtf lol
Given all the flooding, hows the cellar looking, still running?
How far has he gotten with the ambients, there was talk about enclosing them and then just pumping air through a smaller semi sealed setup rather than cooling a whole room etc.
How close is he to water?
Or more importantly how close is the water to him! Lol![]()
As the GPU's are sensible temps it's the PSU's which are struggling... Some way to isolate them from the GPU's and pump some cooler air at just the PSU's might be another alternative...
They're (probably) Gold/Platinum rated, but that is purely their 'efficiency under load', the ambient heat being so high will have a massive impact on their efficiency (therefore having a knock on affect of this rating and the life of the capacitors themselves!).
GPU's are made to cope with high temps... PSU's maybe not so much! Once the outside ambient starts to rise (rumour of a heat wave in March!) wndsr may find a huge increase in failures and overheating probs!![]()
How much are you making a month with all these rigs? lol
Air con would never work, you need to shift the hot air out of the room. Air con would be using energy to create cool air and shift it in.
If you can extract the hot air, that's the way to go IMO.
Air con would obviously be the best option. Have you ever been in a server room?
Air con would obviously be the best option. Have you ever been in a server room? The only way to keep equipment cool is by actively pumping the heat out. Don't think of air con as "creating" cold air - think of it as pulling heat out of the room and dumping it into the outside air (those big boxes on the outside of buildings).
An extractor is only going to be as good as the ambient temperature of the air that gets sucked in - which will probably be from the house/outdoors - and could get pretty toasty in the Summer.
