Wndsr, I have a fairly good solution for you.
If it comes to mad projects involving rads, I am a master of it![]()
Why not build a mininig tower?
By tower, I mean a box locker - the type you see at gym clubs, but large enough to accomodate rads and add shelves for each rig.
Then cut holes in right wall, attach a Phobya 1260 or 1080, they come with some nice accessories, like mounting system/box etc. If one per rig is not enough, add another on the left side as well
If you cant find a suitable locker, get some aluminum from a company called aluminiumwarehouse, they have everything in their shop to build custom furniture - I made a computer desk from their stuff.
wndsr;25638879My biggest challenge at the moment is figuring out how to get all the hot air out from my cellar as efficiently as possible.[/QUOTE said:Could you not have some fans blowing the heat from the rigs towards the entrance of the cellar?.
Just a heads up a competitor has gigabyte 280x windforce cards in stock at £224 but only 20 in stock. OCUK said they cannot price match, around £60 cheaper.
Bargain.
I'm sure you've considered this but I have to ask! I hope you have considered the amperage you are going to be pulling from the wall from these machines! Definitely worth making sure your home mains can take the load!
Good luck with this! I think its a great project! Why not build a rack with all the machines in and set up hot/cold sides and use a large boxfan to channel the air away?
Bargain.
Wndsr, apologies, only just seen this now.
Looks like it's going to be fun. Good luck, and try not to burn the house down![]()
Could you not knock out some bricks, make a wooden frame insert and add some of these http://m.screwfix.com/reviews.htm?id=12523. That should be pretty easy.
So jelly. I wish i was a drug dealer so i could get a new GPU![]()
I'm building my first mining rig on Wednesday when my components arrive, so looking forward to that
although it will be nothing like the scale of this one!
