Mother Mine - Extreme Mining Setup
I know you are all hungry for photos, they will come tomorrow! :D
Everything has arrived now. My final specification for the rig was as follows:-
Intel Celeron 2.7Ghz Dual Core CPU
8GB Team Group DDR3 2400Mhz RAM
4 x Power Colour 280X GPU
1300W Antec Platinum PSU
30GB Kingston SSD
AsRock H61 Pro BTC
The frames will be made from aluminium with 3 cards mounted and 1 in the actual motherboard. I've struggled to find long riser cables for PCIx16 so this will do for now.
Total setup...
20 x 280X
4 x 290
Will post pictures soon.
30GB Kingston SSD
AsRock H61 Pro BTC
Total setup...
20 x 280X
4 x 290
Is there any reason for 8Gb of ram and the SSD?
I'm thinking about getting 2 machines like that and running linux from a pendrive without a HDD/SSD.
Scrypt Mining likes RAM because it allows for a higher thread concurrency. One of my current systems is limited to how 'intense' it can mine because of its lack of RAM.
The SSD uses less power than the HDD - only reason. Linux is very good and seems stable though as you can't easily get it to mine to multiple pools I favour Windows.
Looking forward to seeing this. :) May I ask how much this will cost and have you worked out what your monthly electricity cost is going to be?
My costs have been just over £5000 currently. That's including everything from all the hardware, the networking stuff, the fitting of new plug sockets, the PCI risers.
Power wise I am probably looking at over £300 per month. Will do a full power test when I am up and running.
As promised...
I thought thread concurrency was multiples of the shaders in the GPU?
I have 16GB of system ram but can only use 8192 thread concurrency on 7850 (8x 1024 shaders), any higher and cgminer just fails.
Depends on the coin, if he does Dogecoin which is the most profitable at the moment he can make about $3500 a month and depending on his electric tarrif itll cost $900-1000 in power.
I ordered 6x 280x, but from where I bought will have in stock only in 10 days, so I might cancel that. :(
I'm thinking about getting 10x 280x here on OcUK to join the mine freaks team :D
Has your electrician been out yet? I'd imagine the main fuse in your service head is 80~100 amps. I take it your house is on a typical single phase supply?
