hi I'm getting OCuK to build me a watercooled pc and was wondering if a Monoblock is better, it's going to have 2 360 rads
Certainly people have managed 18, maybe 24 months. Others have a regular 6/12 month maintenance routine. But unless you plan to get rid of the PC in 2 years, it's best to plan for said maintenance. It WILL need doing one day, so I recommend knowing your drain technique early on.they said it won't need touching for years, I thought it was recommended to to drain and clean the system yearly
think I Will get them to add it, I asked was a drain port needed and they said not really as it won't need cleaning for years is that correct and should I add anything else that is essential
...monoblocks are fine for the most part but some boards they can hamper cooling the VRM properly compared to just a CPU block.
