Hello all, so on my journey to building my nas I encountered a problem, long story short I took a gamble and bought a £16 foxconn motherboard from ocuk which arrived last week - I also bought a bitfenix case, however in my haste I didnt check to see is the case and mobo were compatible (micro atx board mini-atx case...rookie mistake eh).
So, same day last week I re-ordered the original board I had planned to get - asus p8h77-i (again from ocuk), which arrived today!
While waiting I decided to see if I could get the nas setup ready, so I took apart my old pc to install the new components - and everything worked fine with the foxconn board, and has for the last week (freenas however can be a bit tricky but I got ther in the end).
When the new board arrived today it should have been as easy as moving things across to the new board but I've encountered a problem, I have everything setup (minus hard drives) but when I try to power the system on the fans on case and cpu fan start to spin then just stop, it wont post, after dl checking the asus page it looks like my cpu isnt supported until bios 1004 (its a g2030) so decided to pop out mt 2700k from my main rig just to update bios - but im getting the same problem, fan starts to spin but then stopps (doesnt even get a full rotation in)
So anyone have a simple solution or can think of something simple.im.missing? Thanks in advance
.While waiting I decided to see if I could get the nas setup ready, so I took apart my old pc to install the new components - and everything worked fine with the foxconn board, and has for the last week (freenas however can be a bit tricky but I got ther in the end).
