- 8 Aug 2010
- Oxfordshire
And yes, th sweet spot agument is not fully correct but it is a fcat that most lenses tend to have softer edges so when you use such lenses on a FF camera and the image is displayed at 100%, as in you printed to the largest size possible at 300DPI you will notice softer edges than if you used the lens on a crop sensor
No this is wrong. Yes we all know and agree lenses have sweet spots. Where I disagree is with the notion that the corner sharpness is better on crop sensors due to falling within the sweet spot.
You are not taking into account the area advantage of FF sensors that allow it to utilise a larger surface area of the lens.
Note: only in exceptional circumstances where the lens has positively crap performance in the corners relative to the center, is this not the case.
There are lot's of sources showing this, but below is a nice visual representation.
http://www.dpreview.com/lensreviews/nikon_50_1p4g_n15/4
As for the other stuff you'v said about new tech being able to close the difference between full frame and crop. Your point is really apples and oranges. Canon's sensor tech has barely improved since the 40D, yet Sony has made big strides. To be an apples to apples comparison you should compare current tech, with current tech of the same manufacturer.
