I know its not a 290X but my ASUS ROG SWIFT allows 120hz on a 295X2. 144hz is a no no
Cheers and I assume that is with DP?
Nice little review Greg, but im sure i'll be waking up soon, as i am dreaming, aren't i ?![]()
Does your monitor allow you to get 120Hz.@ 1440P Shanks?
Hopefully a different lead will sort it but seems strange that the same lead worked fine @ 144hz and 1440P on the Titans.
Mantle smoother than Titans @ DX or just the same? For me, it was the same. No problems with it but I didn't have probs with DX on the 780.
Downsampling The Easy Way With Custom Resolution Utility (CRU)-Running On AMD
CRU-the program you need:
http://www.monitortests.com/cru-1.1.1.zip
Before you do anything, create a System Restore point, it's a handy fallback to use in Safe Mode should your monitor go out of range.
Run CRU as administrator, allow it through smart screen if need be(W8).
1. Untick 'Include extension block'
2. Click 'Add'
3. Input Horizontal
4. Input Vertical
5. Optional if you have a 120Hz/+ panel, Input Refresh rate.
6. Press OK, and restart PC.
snip
Notes:
I had to unplug my second display as it wouldn't work with both plugged in-your mileage may vary though.
I would advise leaving your native resolution on the desktop and using in game settings to change individual game resolutions as the screen goes blurry when running out with your native res.
