Are you still on standard anti roll bars?
They'd be my first port of call of ridding a car of excessive bodyroll if it already has some form of uprated suspension.
It's a Sport thereby the ARB's are massively uprated compared to the base model already. That's not to say it's not something worth looking into still, for now though I'd sooner have hard springs in there.
Sorry, only just saw this.
On my E46 FCAB were a must. I also did all of the ARB bushes and the RTABs. The RTABs on the E36 were meant to have an even short life expectancy than on the E46! RTABs and FCABs reduced the tramlining/high speed "instability" i had significantly. Then getting rid of the Bridgestone tyres eliminated it altogether.
Also, i had a leaky rear shock by 65k and 8 years old and replaced both rear shocks and top mounts as a precaution. Also i replaced the front drop links which were like £25 for both and took a whole 5 minutes for the mechanic to fit - definitely worth doing.
Should be able to get ALL of this done for around £300. Quite a bit less if you can do everything yourself. If your E36 has never had any bushes etc changed, the difference should be massive.
EDIT: Sorry, only just read about your friendly mechanic![]()
Thanks, I've been looking into the bushes today. RTAB are easy to get, Meyle HD ones should do I think, not sure if I should go for Powerflex polyurethane ones.
Front ones seem tricky though, they are solid eccentric bushes on the Sport (being solid, you'd think there's limited scope for wearing out, but whatever..). Can't find Meyle HD ones, although you can buy them as part of a control arm kit easily. Will continue looking.
