Is this a rhetorical question?
What happened to the easy rider shuffle? I remember that thread.Got a 3060ti FE for £369
What’s my upgrade 2 years on ?
thanks
What happened to the easy rider shuffle? I remember that thread.![]()
yeah odd thread. Nothing touches the FE price, maybe pirate the @TNA shuffle then?Funny thing is it is easier than ever to do it right now.What happened to the easy rider shuffle? I remember that thread.![]()
I am going for a 3070 Ti 16GB FE soon and will upgrade that to a 4070 FE. You lost your touch it seems and stuck doing the five knuckle shuffle…Got a 3060ti FE for £369
thanks
eBay tho.... /shudderI think the sequence would then be:
Secure a 3080FE drop (costs 649)
List ti on thon bay BIN (sell 700)
pirate TNA shuffle complete! you have £50 and now a 3080 instead of the Ti.
What happens when you Pollytunnel and stuff I guess..
Yea, I would never do that. Not taking chances on there.eBay tho.... /shudder
Good luck not getting scammed, because the buyer is always right. You can send them a GPU, they claim you sent them a brick, eBay refunds them and you are screwed.
Seen it soooo many times.
CEXOh yes you used the local pawn shop place didnt you!![]()
My FE 3060TI runs very, very hot. I keep meaning to under-volt it, when I get around to it.Do fe 3060ti and 3070 also suffer from vram temps due to pads not being thick enough?
