- 25 Nov 2009
Hello all,
Background: I'm a fitter, I have no computer/IT experience what-so-ever as you'll gather if you go through my previous posts
I hate software, driver issues, data cloning etc etc but I enjoy building/benching my computer.
I started 4 years ago with a mighty PhenomII X2 550 in a n Antec 300 this kind of progressed into an X4 955 with a H100 but ultimately I always knew I should have gone intel...
Fast forward to the last 3 months or so, I have collected the following parts-many thanks to this forum for the 2nd hand bits! (ToxicTbag, Greboth, Dirtychinchilla, Skylineboy, Stulid and no doubt others too) the only parts to survive the revamp were the RAM and Spinpoint F3 1TB
2500k
Gigabyte Z68XP-UD4
Samsung 840 250Gb SSD
HIS IceQ Boost 7950
Seasonic X series 660W
Carbide 540
Akasa 6 channel fan controller
4 SP120's
XSPC RX240
Phobya 240mm
EK DCP 4.0
EK nickel compressions/rotaries
XSPC Raystorm
AquaComp 7950 Block
Primochill tubing
Pump>GPU>Rad>CPU>RAD>Pump
The case was the final part to the puzzle, I got home from work on saturday afternoon and set about building the rig up. This was my first proper attempt at building a fully watercooled rig
Here are a couple of pictures, it aint quite perfect but it's perfectly usable and gamings temps at 4.5GHz and 1100/1500 @1.205v are 48*C and 37*C respectively.
First tube in
Plumbing done
Started to fill with water
Et voila
It's no 4770k TriFire 7990 but for playing todays FPS at 1080 it's flawless
The only thing I want to do to it really is get another 7950 for crossfire and tidy up 'the darkside'.
Thoughts and comments welcomed
NoNNoN
I hate software, driver issues, data cloning etc etc but I enjoy building/benching my computer.I started 4 years ago with a mighty PhenomII X2 550 in a n Antec 300 this kind of progressed into an X4 955 with a H100 but ultimately I always knew I should have gone intel...
2500k
Gigabyte Z68XP-UD4
HIS IceQ Boost 7950
Carbide 540
4 SP120's
XSPC RX240
Phobya 240mm
EK DCP 4.0
XSPC Raystorm
AquaComp 7950 Block
Primochill tubing
First tube in
Plumbing done
Et voila
NoNNoN
