- 19 Jan 2012
okay guys I'm hoping someone can help and put the pieces together
I have so many problems on my new pc
I recently built a new pc, using the old HDD from my old pc, I have deleted all partitions and done a clean installation of windows 7 on it (multiple times now)
specs:
RAM: G Skill 8GB (2x4GB) DDR3 1333mhz Ripjaws
GPU: nvidia GTX 570
CPU: Intel 3rd Generation Core i5-3570K
MOBO: Asus P8H61-M PRO REV 3.0
HDD: (salvaged from old build) Western Digital WD5000AAKS 500GB SATAII 7200RPM 16MB Cache
PSU: (salvaged from old build) ICute AP-700AS (700w)
case: antec 302
cooling: Corsair CWCH60 Water Cooler
and i have had so many problems
heres a list of the many problems i have had:
- turning my pc on the first time is when i realised something is ****ed, it would turn off after 3 seconds and restart, this would continue on and on at the same the the red light indicating something wrong with my memory would light up
- having used the MEMok! button on my motherboard i managed to get my pc started, it would go all the way to the windows screen before freezing and showing a blue screen with the error "PAGE FAULT IN NON-PAGED AREA" again another RAM problem
- these two problems still happen to me very often every time i turn my pc off and on it will continue to restart itself then randomly stop and go all the way to desktop
- i'm actually currently using my pc now to type this.
- my pc wont install updates it will get stuck at 0% downloading, installing or configuring updates, i can't even update my net framework...
I was hoping someone can pinpoint the problem, at the moment I am pretty sure its the RAM but i cant seem to be 100% sure because it is BRAND NEW!?
many thanks in advance!
Tommy
specs:
GPU: nvidia GTX 570
case: antec 302
Tommy
