Could your hideously bent front end have caused the diff/driveshaft to be misaligned compared to how they are designed to be and the put uneccessary load on them?
I'd sell it after fixing it.
[TW]Fox;14246464 said:Also how did you manage to find a gearbox with '40k motorway miles' on a car which was at best 5 years old? Who only does motorway miles but only ends up doing under 10k a year?
I am with wicksta, fix it, then sell it. If you want another one buy another one![]()
This is exactly what I said when the drive shaft first went...wouldn't believe me mind.
[TW]Fox;14246589 said:I think the sensible thing to do might be to scrap the whole car - who knows what else its hiding after you crashed it (oh wait sorry your brother nicked it and crashed it, is that like the oncoming car when you crashed the Astra) and then had the repair bodged
p
You'll end up throwing more at it than buying another! Get rid of it![]()
These gearboxes are very solid anyway so I'm not that fussed if its more.
It appears that dealing with sheds is a family trait![]()
I thought your family ran a breakers yard?
I was up there the other day, there was this MG...ooooooohh...
Have you seen this video on youtube?
It should help you, I think it's the KV6 that went into the 800's but it still applies to your engine.
Also you should change the water pump as well.
