Project: Ice
Welcome to My 600T Watercooling Project
Hi all,
This is my first attempt at putting up any form of lengthy build log so i will give it my best shot and hope it turns out well. My camera is far more capable than i am but it is only a compact, will do my best to portray the work but don't expect the amazing arty shots that you can find elsewhere.
I'm not going to blabber on too much about what and why because i know you just want to scroll through pictures really
, but here is a brief overview.
EDIT: I need good name for the project and case but im really bad at names, suggestions welcome.
Why?
Loud Coolit Vantage ALC
Loud fan grills in 600T
not done WC before.
What?
Rig in Sig
Raystorm CPU Block
Magicool 360mm Radiator
Bitspower fittings (inc T-Block for draining)
Laing DDC 18W
EK DDC X-Res 100
Mayhems Pastel White Coolant
Added to the project:
Phobya 200mm Rad
HD 7970
EK 7970 Waterblock +Backplate
Aim:
Easy draining and filling for when i move the case about on a fairly regular basis.
Super Cool CPU temps
Nice and quiet
So lets Begin!
Here is my rig as it sits at the moment, the only difference is that the Scythe GT fans have been died white.
Here is the kit I plan to put in with an additional image for the coolant because I forgot it initially. Oops
(I do have more fittings, but didn't want to unpack them all.
Temp sensor (not decided where to mount yet. Fill port perhaps?)
Bitspower T-Block, this will give me an easy port for emptying, not sure how it will affect my flow rate though (answer on a postcard please)
Couple I questions I have:
What is this? (Is it radioactive?
LOL)
For mounting my Laing DDC, I have heard they tend to rattle the case a bit. I have some foam tape and a velcro sheet. Not sure how to use/mount (more answers on postcard appreciated. Posting a reply might be easier)
Since I move my case around fairly often, it is key that I try and maintain the strength of the case, so I need to prevent cutting out huge holes. I went through a couple of designs but ended up on this:
Top
Front
Once cut it all looks a little bit like this:
That's all for now. More updates on the way...
Up Next, filing down the sharp edges and some slight modifications i made to the holes.
Hi all,
Why?
not done WC before.
What?
Rig in Sig
Raystorm CPU Block
Laing DDC 18W
EK DDC X-Res 100
Phobya 200mm Rad
HD 7970
Aim:
Nice and quiet
So lets Begin!
Top
Front
