As above really! (Just to balance the stellar overclocks some others are getting!)
From the Bios (Updated to F3 by the way), it won't budge from the stock FSB no matter what I do with voltages or RAM dividers.
I can get it to 2.1 Ghz with the Gigabyte easytune software in Windows, and it scores a 26sec 1M PI result.
Back at stock and using my usual benchmarks, it scores approx 15% higher than my old Pentium D940 which was overclocked to 3.7Ghz, which is ok I guess.
Havings said that, I'm glad I didn't spend a fortune changing to the chip! Games performance should take a boost though.
I think it could be my RAM holding me back, or something else I haven't worked out yet!
Edit: Any advice more than gratefully received!!
