Worst I have an expensive watch thread ever!
I have some belly cooking tonight with this method (though I didn't have time to dry out the skin for two days so I used a hair dryer instead).
That's a good idea, I might try that next time to save the hanging around period and add to the possibility of getting an instant crispy pork hit at a moment's notice (well, 4 hrs notice anyway).
It worked really well actually, though I definitely over-salted the crackling. It was kind of inedible, but the texture was awesome
The pork itself was great though I wish I'd had the patience/self-control to leave it roasting for an extra hour.
I've got some in the freezer. I love a good pork belly and have been playing around with temps and times. Best I've found so far is put it on a wire rack, with water underneath, cover whole top with foil and pretty much steam it at 80 for about 6-8hrs(depending on size of belly). Make sure that the water never goes dry too. You can rub the meat before hand but then also flavour the water. Then, salt skin and cook for 30minutes on 190 it will puff up nicely.
I normally brush the salt off with a basting brush (or whatever) after it's cooked. If you use salt flakes, its easier to remove the salt that if you grind it on. All that effort for over-seasoned crackling is the most disappointing thing ever.
Sounds good.
Speaking of presentation, I once did the slow cooking part the day before we ate it, then left it in the fridge overnight compressed by a heavy baking tray and some food tins. Then when you want to eat it, you simply wack it in a pan skin side down (from room temperature) to heat through and get the crackling going.
Works really well and the 'compress and cook twice' tactic both increases the flavour and flattens the layers of fat, making it (arguably) more pleasant to eat if the fat hasn't rendered completely.
