Just looking at your SSD Drexel, did you use sticky velcro to hold it there or just sticky pads?
If so, which ones did you go for?
Just some generic foam sticky pads I had lying around.
Hi Drexel,
What do you think you've spent in total on that system out of interest?
Thanks
I have almost the exact same build after reading this drexel!
I will be following you an getting a h50 and a 260 in there, do you know if the cyclone version would be much better than that card? As in temps/noise?
Have you experemented replacing the stock H50 with something else?
Did the GFX increase temps much? What are they like now?
thanks
Quick question for you DreXel - did you have to modify the mounting plate for your H50? Just doing some reading and there are quite a lot of people out there saying the plate fouls a component on the bottom of the board...![]()
I didn't mod mine, no. I have since read about the issue of it fouling components underneath, but I did mine before I had even read about any issues and it's been fine. If I were to do it again now I would do the mod just to be sure, but I'm not about to take it all apart again![]()
Drexel, out of interest do you run with just the SSD for storage or do you have a bigger, external drive?
