Cheers, bet you never wished you started this thread now?![]()
Lol, not at all, I'm glad it's inspired/helped people out
Which card is that exactly?
Does the gigabyte run as cool as the other one though?
Can anyone link me to a cheap good DVD drive (possibly slot loading?) for the SG05
New stuff to me![]()
Drexel,
How are your temps under full load in that case? Have you tried a decent gaming session yet to see what good usage warms it up to? Do SSD's suffer from high heat like hard drives do?
Drexel mate, just looking at the ATI 6 series but I was wondering, how long exactly do you have to play with in terms of graphics card in order to still be able to accomodate the H5O?
Any gotchas with the i5/H55N? Did you top out at 4ghz, or get it any higher?
Cheers
Yeah, it's a great little case which is really well ventilated, and the front 120mm intake fan creates positive pressure inside the case and forces the hot air out through all the ventilation holes![]()
