Hi Illuz - don't mind at all
I've lost count to be honest - but roughly
600 pounds for the case (but the case is really a luxury so you could save a lot on that)
Watercooling stuff - including fans, rads, res, x2 gpu blocks, 1 cpu block, compression fittings, tubing - roughly 900 quid. I know, I know, but you could save a packet if you just went with barbs and not comp fittings. I bought too many anyway, so overspent there.
The only hardware I have bought is the mobo, cpu and ram, which in all came to about 800 quid. I have the gpus (x2 gtx 570s) drives, fan controller, optical drives already, so I saved there. If I'd had the money I would have upgraded the 570 to the 670s but that's another 600 pounds, which was too much for me in the end. The cards I have now are really good in sli (great scaling), so I'll stick with them until the 7 or 8 series comes out (if they come out).
So all in all, and it terrifies me to say so, I spent around 2300 pounds, but if I knew then what I know now, I could have saved a couple of hundred quid.
