Caporegime
- 11 Mar 2005
- Leafy Cheshire
On a side note, anymore auto light issues martin?
Technically, the air should all be moving in the same direction unless there are phase issues.
He's been through this with me, but basically, the box has a slight annoyance issue when kicking down into a gear which I forget (2nd I think), regardless of mode of the box.
However, after a bit of reading, it is potentially a pretty (relatively speaking) cheap, if fiddly, fix.
I'm a big fan of cheap ICE.
My last ICE system comprised of 5 Sinfoni amps, a Pioneer P9 running fully active Focal Utopias with a Focal sub in the boot. It was all installed professionally and RTA's by Mark Turner.
My current system is a cheap Pioneer head unit (£100) a set of Alpine components (£80), a Kenwood 10" sub I had lying around and a 4 channel JVC amp (£100)
Considering my current system cost less than the RCAs did on my last system it sounds damn good.
I've done the expensive ICE thing and it's just not worth it. It's a law of diminishing returns and I think that a sub £500 system can produce 90% of the quality of a £10k system as long as it's installed and set up correctly.
Pffft, amatures, this is cheap ICE
Actually, that phone probubly cost more than the OPs install....
Just a thought, but won't the 6x9s get a hammering from the sub when they're trying to push air against each other? Is it possible to box them into their own airspace?
