amdegelas said:Quick tip to neaten the engine bay - thread as much of the loom as possible through the chassis legs. Me and a mate did that with our supercharged vr6 mk2 golf that we built.
It's been snowing all day here, done nothing in the SupraL1J said:Been a bit busy today, will drag my arse into the cold garage in a few minutes.
LOL at 'special fluid'
Looks like I will have to burn the midnight oil next week.
)Lopéz said:Those bushes are very stiff - Gareth used them on his Mk1 and his brothers Mk2 (My old white Mk2 - remember that?)
Mad old tory said:Looks a cracking project, was wondering though, how do you go about getting insurance on a car like this with such a major mod as an engine conversion?
L1J said:That particular night of slidng a few inches from the side of a sheer drop in your Mk2 will never be forgotten! Most scared Ive been in a car ever!
How stiff is very stiff? Shocks will be Koni TAs and standard GTi springs, should be ok for a daily driver I hope.....
The powder coaters I went to do wheels aswell, will get a quote for a refurb.
Lopéz said:Very impressed with the gel! Time to make an order - did you get yours from the manufacturer?
Some more bits I've aquired over the past week!
Polybushes
Engine mounts
Left to right - rear engine, gearbox and front engine/gearbox (solid)
Some wheels I found on German Ebay
Not sure what to do with these yet, might use them as a trackday set or get them refurbished as I think they would go well with the red? Opinions anyone?
Barry Smalley said:Qpeng stuff offers an easy solution and Emerald is supposed to be ok, but what about DTA? It's supposed to be very very good for the 20VT.
Not sure on the weight differences of the 20VT and the PB engine, but I think you definitely need to think about putting coilovers on to get your height bang on. Koni T/A's and standard springs would certainly be interesting, as the Koni bodies are shorter than standard fayre.
Are you on ClubGTI? If not, you need to be - plenty of good advice over there.
The wheels? From a sportline, or are they just black centres? I'd get some nice 8" RM's on the car when it where finished. 6"/7" wheels don't do anything for the stance.![]()
lozza23_uk said:oooh you wont like that front engine mount. solid as a rock.
