My graphics card isn't detecting!
What kind of HDMI cable is that? It looks like a round connector.
Have you tried the DVI/VGA connection? Whichever one it has.
9/10 of not detecting is because the card is not fully sat down correctly so...
1,,,,take card out and check there are no bent pins and give them a quick clean with a tissue and alcohol
2... check your pci slot just to make sure that it is clear and nothing has become stuck
3.... insert card back in making sure that your release tab comes back up and it is level all the way across
4....plug power back in and boot up
5.... hopefully it should have been detected ... check under device manager
goodluck
It still isn't being detected unfortunately.
Last month there was a thunderstorm which hit my router. My ethernet cable hasn't been able to work since. Do you think this could've had an effect on the rest of my motherboard, damaging the PCI-E slot somehow?
I don't know if this is the answer! I'm only asking.
Is a Corsair VS350 powerful enough? How many hard drives and what memory is installed? Anything else drawing power?
The CPU uses around 100w The card uses up to 150W.
That only leaves 100w for everything else.
Yes happened to me fried components of my motherboard. :eek:
I have 1 have 1 seagate 1000gb hdd, 1 8gb 1600mhz ram stick and an optical drive.
That should be okay! :)
But I do recommend changing your motherboard,
My Ethernet wire went out a bedroom window down into my living room window about 3-4 years ago lightening hit the wire, I had to use a dongle to get internet after that the motherboard still worked but sometimes things wouldn't post, My graphics card etc!
Thanks for replying! That's a massive relief. I thought the gpu was broken. Motherboards aren't too hard to install are they?
No they are pretty easy 10 - 30 mins max, just make sure you replace the
thermal paste on the CPU when it's on the new board, swap over wires, memory etc, that's about it! :)
