My other Golf Project!
Last coilover we stripped down today was knackered, piston will push in very easily and won't come out unless you pull it. Looks like we will have to order a new set of coilovers.
Rear beam mounting point cleaned up and given a coat of hydrate 80
Plastic wheel arch taken off to find arch rolling by demon tweeks.....
Rust removed with a wire brush attachment and flap disk
Coat of hydrate 80 again
Will need another once its dry
Petrol tank brackets removed for powder coating
Rear beam brackets, the beam itself and a few other bits will be powder coated this week.
Found a few other things that need to be ordered so we can carry on:
Copper brake pipe to make some lines up
Flexi brake lines front and rear
Rear wheel bearings
Rear beam bushes
Once the rear is back in place we can start putting the engine back in again! :D
Damn! Awesome work there!
Loving that Hydrate80 stuff, going to have to get some I think. Got some rust that needs to go bye bye :D
Llyr, can you not get the coilover revalved or reconditioned? I'm sure AVO offer the service.
Llyr, how much does powdercoating cost? It it on a per item/batch/weight basis? I assume the shotblast and degrease the bits before coating them?
Tony (the owner) wants to fit a new set, the ride was "interesting" with these on!
Yes they degrease and shotblast before applying the coating.
Last batch we did on this car consisting of
was £95 for primer and paint. I have no idea how he prices stuff up to be honest, I usually turn up with a bunch of items and he gives me a price. I'm assuming he does it on the labour time for shotblasting and how much coating he thinks he will use.
If he has a batch of the colour you want going through at the same time the price tends to be cheaper. He usually has a minimum charge of £30 so I try and take a lot of stuff at once. I've also noticed the more I use him the less the price seems to be!
I've got a mate that works at a powdercoater's, I got all 4 of my wheels shotblasted, acid dipped and powdercoated for £120 :D
Is the guy not tempted to do cash-in-hand jobs then?
I think he quoted me £35 per wheel for a refurb, so his prices aren't that bad at all. I've always paid him in cash ;)
/sees scary looking wiring and runs off :D
It wasn't that scary!
Wiring half sorted today, all the wires for the engine have been identified and all the original loom that's unused has been removed. The two runs below will need to be combined once the engine is in. The one on the left is for the engine itself and the one on the right is for the instruments, oil warning lights etc.
It looks a lot better than it did this morning!
Wheel arch now ready for paint, the back of it was also undersealed
Hopefully the rear beam will be back from the powder coaters next weekend, once the back is on the floor we can put the engine in and try and start it!
How did you manage to strip down the front cross member (top of pic) ive got a spare ive been trying to clean up but cant get the bushes out at all?
The big washers on top of the tubes that go through the bushes will break off if you use enough force. I used a pair of mole grips. They tend to bend when you remove them. I straightened them up and dressed the tube and washer with a file before putting them back together.
Engine started today :D
It was put back in last weekend, and the wiring put temporarily in place to make sure everything was working.
Yes it's messy!
Trying to connect my laptop to the DTA using a USB to serial converter wasn't succesful so plan B of taking my main PC and an old monitor into the garage was put in place!
The DTA software has a really useful screen for checking all the inputs
Found a few wiring faults:
MAP Sensor wiring broken
TPS wired incorrectly (was seeing full throttle at closed throttle and vice versa)
Silly settings found on the original ECU map, really weird things going on. Engine had 121 cylinders, 8 injectors, rev limit of 14999RPM and incorrect settings for the crank sensor. No wonder it wouldnt start when we got it!
The DTA software comes with a base VW1800 Map so I uploaded it to see what would happen.
With the above done we turned the key and it spultered into life. :D
We need to connect the cooling system etc up now and let it run for a while to try and find any potential problems.
Progress at last! :)
Few bits done over the weekend:
Rear beam before
and after
Underside of the car after rust removal and sealing
ECU wiring re terminated properly and tidied up
Rear beam should be mounted next weekend. I'm having a little trouble getting the temperature gauge to work on the instrument cluster so need to look into that.
what do you use to protect the loom under the bonnet? the plastic shroud i put around my loom that goes over the exhaust manifold area is dying again. need a better fix
Some more done.
The car now starts first time and idles :D
It's back on the floor and we've turned it around for more space to work in. The bumper bar has been modified to let some more air to flow to the intercooler.
All the pumbing has been put back in and we've found some more bits that need modifying:
Turbo outlet pipe fouls on the heater hoses and coil pack
Lambda sensor fouls on the rear engine mount
Tony is going to call the downpipe supplier during the week as the one I've used on my mk2 goes in a different direction and has plenty of clearance.
Laptop can now be used to monitor the ECU by using a PC Card to RS232 adapter, the Hi-tech workstation!
Does anyone have any experience of using the DTA mapping software?
