Hey All,
I thought I'd make the idea for my next build public to take advantage of all of your expertise!
It's been a few years since I've built or even upgraded anything, but this project has a purpose.
The Build
I'm not a gamer, I'm a computer programmer and I'm likely to be running VMs and using pretty heavy compilation software, statistical analysis software, machine learning, etc.
I'd like to keep the build around the £1000 mark if possible...
So far, this is coming in at around £1200, so any cost saving tips would be appreciated.
What I really want though are suggestions, recommendations and a compatibility sense check!
AMD Ryzen™ 7 2700X
I've been an "Intel Guy" for years now. For no good reason of course. My justification for this is the high core count.
ASUS PRIME X470-PRO
I'm not too fussed on all the RGB hype, but I don't want an ugly mobo! Packed with plenty of features as far as I'm concerned.
16GB (2x8GB) Corsair DDR4 Vengeance LPX Black, PC4-21300 (2666)
The spec is 16GB, to be honest I have no justification for this particular make/model though.
ASUS GeForce GTX 1060 DUAL OC 3GB GDDR5 VR Ready Graphics Card, 1152 Core, 1569MHz GPU, 1785MHz Boost
Like I said, I'm not a gamer. BUT what I do want is to be able to hook up 2 DisplayPort monitors
256GB Samsung PM981, M.2 (2280)
I'll stick the OS on this. Maybe a few of the larger programming suits.
1TB WD Blue WD10EZEX SATA III 6GB/s 7200rpm 64MB Cache 8ms OEM HDD
I won't fill this too quickly.
650W Cooler Master MasterWatt 650, Hybrid Modular, 80 PLUS Bronze
To be honest, I don't know if 650 is 'too much', but I like modular PSUs, I recognise the brand and it was reasonably priced!
ASUS PCE-AC68 Dual-band Wireless AC1900 PCI-E Adapter with 3 Antennas
No hard wires for me I'm afraid!
Microsoft Windows 10 Professional, 64-bit
I've gone for pro so I can use Remote Desktop... But then again, I guess I could use something like VNC?
NZXT Source 340 Compact Black Mid Tower Case with Side Window
I like the minimalist style, the colour, the window, the brand. Other than that, I'm not too picky.
The Build
AMD Ryzen™ 7 2700X
ASUS PRIME X470-PRO
