Work drags on.
Flexi hose is on order and should be at my local motor factor by 11.
Bumper has not arrived at GSF yet but may come in on the next van in the afternoon.
Exhaust is out for delivery with Businesspost but it's headed to my work address and I'm not there.
So, as the car is still immobile I thought I'd do something else.
This is a spare axle I have taken from my other 205. It is in better condition than the one on the red car, so I may fit it in the not too distant future. For now, it needs new brake shoes and I have some handy - so here's a guide on how to disassemble the drum.
Brake drums are held together with a system of ropes and pulleys combined with a sprinkling of witchcraft - my honest advice? Take pics as you go along or do one side at a time, because you can easily forget how it all goes back together!
Step 1:
Pop off the hub cap
Step 2:
Undo hub nut. You will need to use a far manlier grip than the one I am demonstrating in the picture. I had to stand on the axle to stop it rocking about, it's much easier if the axle is mounted to the car!
Step 3:
After hitting the drum cover lots with a hammer and blunt chisel, it will eventually work off exposing the innards of the drum.
The eagle-eyed amongst you will notice I am now working on the other side, I just happened to have the drum cover already off this side!
Get busy with the needle nosed pliers because those 3 springs need to come off. Don't lose any unless you have bought a new kit of replacements.
Step 5:
Now the shoes are only held in by the 2 sprung pins. Can you see them? One on each shoe, roughly in the middle. You need to use needle nosed pliers again and turn the pins, allowing the spring to pop off and free the shoes.
The handbrake adjuster (the long bar with a fork at the end down the bottom) will also fall off at this point.
Step 6:
Release the handbrake cable, on the 205 it just lifts out
Step 7:
One bare drum. It might be worth scraping off any loose rust or paint, and checking the condition of the wheel cylinder (that cylindrical object at the bottom of the pic)
Step 8:
As you can see, the new shoes have a fair bit more meat on them.
Step 9:
Optional bit this. Soak all the springs etc in a strong solution of Bilt-Hamber Deox-C to get rid of as much corrosion as possible.
I'll check on the corroded parts this afternoon, and if they are sufficiently clean, reassembly can begin
