LCB9E 0632
ADA3800DAA5CD
Was woundering if all is well? Used some mx 1 paste with plastic bag over finger using freezer bag (hard since most stuck to bag lol) and some a tiny bit just so covered the heatsink copper plate. And a tiny tiny bit in center of cpu so when hsf went on it would spread it out just incase i did too little on cpu top.
Also installed the amd driver but not optimiser yet, duno if i should or need to? Do i, if so why and what will it help with.
Will temps go down at all if so by how much when paste has done 200hrs or whatever. Also should i not have set the core volts to 1.375 in bios (i think its 1.35 actual volts.) Or perhaps set to 1.35 which would have been 1.3v in actual? Since its rated to be ok from 1.3-1.35 on amd site.
Just expected temps to be 30 or lower at stock.
Also is there a benchmark i can do to see how well dual core is doing wana know if its working properly.
Cheers.
, optimizer is a must yes for games, fixes stuttering.
