N95 auto rotate
Another app available - these programmers work fast eh? No idea what ist like but you can use your N95/8Gb like a light sabre - http://www.symbian-guru.com/welcome/files/LightSabre_S60_3_X_v_1_0_0.sisx
edit - theres a vid of it working here (again quite gimmicky but fun): http://www.symbian-guru.com/welcome/2007/11/lightsaber-app-.html
how do you run it? installed it, click open and nothing happens.
The accelerometer is working as i just tried taking the same photos in portrait and landscape mode then look at it in the gallery it knows the right way up.
GARR!
Not working here either mate, nothing happens anyone got any ideas?
The moving ball still works.:confused:
Ask leftfield - I dont have an N95 at the moment.
Did you instal it to the phone memory itself? You need to do this:
" Install the app (**Must install on the phone's internal memory, NOT the memory card**), and then press the center button on the d-pad to power your new lightsaber on. Swing it around and you get the cool sound effects, including one for when two sabers clash. "
Tried installing the lightsaber on my n95 just now and it doesnt seem to work ie no sounds coming from it:confused:. Installed to the phone memory and also installed the API as well...got moving ball app which works....strange
Got rotateme now, working a treat. Only downside, being an app, you need to leave it running in the background and run it again if you reboot your phone.
