doggo said:I'd also recommend tomtom, just get a cheap gps receiver off ebay, you can pick one up for about £25
I've been using tomtom on my n73 for about 9 months now and it's great.
doggo
StaticThought said:N95 has a built in GPS receiver. TomTom here as well. On my O2 Orbit.
alexslane said:Hi mate ,
i am using route 66 on my n95 , and go to say works a treat , seems to work a lot more efficient than the nokia maps ,
if you can get route 66 you wont be unhappy with it , put it this way i have just come back off a holiday with the family and it has got me there and back no problemo , 300 miles with out a glitch.
Alex Slane![]()
lolism said:thanks Alex, does it cost to update etc? I heard you have to pay for nokia MAPS?
alexslane said:Hey mate ,
route 66 will work with the internal gps not a problem make sure that you use the version (Route66.Mobile.v7.3.486) . now getting it installed can be a little tricky < it took me a little while to be honest.
yeah the nokia maps does cost thats why i opted for the route 66 compaired to nokia maps and just to confirm i have had a play with tomtom on my mates vario2 and there pretty much the same , all the hype over tomtom verus the rest is a bit of banter i feel as we did a route in the same car with both working and they both showed the same options .
if you add me to msn i will be happy to help you with this no problems at all i got ton up on tons of free apps and maybe the odd route 66 present for you i am sure![]()
Look forward to speaking to you
Alex Slane![]()
Youstolemyname said:Would like to chat about route 66 too alex. My MSN details are in my trust.
Thanks
TBirdUK said:can you use any of these on the N70?
alexslane said:Aright fella , had a look in your trust and could not find ya details
Alex Slane
