NAS - Small business setup help
3 Jul 2008
Hi Forum Members,
I have put this off for ages and thought today was the day to ask...
In my business I have 4 computers, each with a OS drive and a additional SAVE drive. We are sick of passing files back and forth on memory sticks, and having duplicate files on different machines, at different stages - NIGHTMARE! Getting very hard to see where latest version is.:confused:
CAN ANYONE HELP ME WITH THE DECISION OF WHAT TO GET?
USE
• Connect 3 - 5 computers to share documents from 1 location
• Some documents are over 1gb (photoshop files)
• Also need wifi (but what would performance be like?)
• I WANT BACKUP
• 2 TB's ex. backup
Like anyone would like it to do the job, be reliable and at the right price.
There seems to be so many options, I have put it off for a whole year!
All help much appreciated.
Kind regards
john
With files over 1Gb I'd forget WiFi.
I setup up something similar just using an old pc in a corner of the office.
Don't forget op, redundancy and backup are both completly different! I would go for redundancy in the server, and buy a 2Tb external for weekly offsite backups.
Depending on how good you are with computers and your budget you could build something and stick it somewhere in the office or you could get a synology/qnap solution. I have the Synology DS210j with two 2tb drives in raid and I can't fault it. You could get a 4 bay one or something, the software is very easy and you can hook up printers for sharing and ext hd's for further backups?
