NAS suggestions for home office / streaming.
29 Nov 2002
Midlands. UK
I currently have a Windows PC serving as a home storage and PLEX media server. However, its getting quite old now (its from 2011) and i fear for data loss and the general expense of running due it it being on 24/7 (it dosnt recover from low power states so its on full power all the time).
I am looking to get a NAS to replace it, ideally with 4 bays so I can have plenty of storage space 40TB + also id like it to act as a data store for file storage in my new home office that has 3 - 4 employees accessing it remotely for light usage. How will a NAS compare in terms of transcoding performance for PLEX users, as currently the PC i have is capable of doing about 2-3 streams before it grinds to a halt, but ideally needs to be able to serve a minimum of 2 users (1080p).
Can i set up a file store that is accessible to both windows and MacOS users, and ideally a way of letting users access the data via their iPhones would be a great benefit so we can have a central repo for all our photo data.
Idea's welcomed.. So far i have sort listed the TERRAMASTER F4-423 as it seems to tick a lot of the boxes?
Grab yourself a n54l from the bay.
Chuck a low profile gpu if needed for transcoding.
Sorted.
Not a bad idea but looks dated now even if I can find one, so I wouldn’t get much warranty ? Also it’s physically quite big despites its micro layout compared to NAS at least?
Footprint is tiny.
I can't speak about the aesthetics, depends if you are going to be inviting people round to look at it....
Power consumption is minimal.
They are solid bits of kit, mine has been running for I can't remember.
I use it for running my Home Assistant, legal torrent server, media server, network file server and backup.
The only warranty I'd be concerned about is on the drives I put in there.
Footprint is tiny.
My current machine has 4 x 3TB WD Red, but would likely move to 2 x 10TB WED Red or Ironwolf NAS .. cost permitting. What OS do you run on yours? As i want to remote into it, and using windows is just overkill and a terrible experience when trying to remote connect.
Win server 2012, I think.
Rdp is easy, no issues.
Just make sure you have a user account on there which matches that of your desktop.
Most of the management I do is Webgui.
Once you've got your shares setup, theres not much else to do.
Access to files on a NAS for Windoes or MacOS is just a matter of enabling the SMB service for Windows and AFP for Macs.
The only problem with the Terramaster F4-423 is finding a stockist. Consider the Asustor AS5404T as well. I'd suggest the s/h AS5304T I'm trying to shift but it might be a bit weak on the decoding.
N54L
(H*W*D) 267 x 210 x 260 mm <-- this seem to be the main issue with its size its too tall to fit under my TV unit, but nice idea.
N54L
Good to know.
You could put it somewhere else.
I've chucked mine in a cupboard.
The possibilities are endless.
As long as you are not attempting to file share outside the lan by opening ports, in which case you will need to implement a vpn server (I recommend Wireguard).
I recently picked up a Synology DS423+ and chucked in 2x Toshiba 18TB MG's and an extra 16GB RAM along side two other drive I have to give me a nice little 41TB setup which is working well. It felt like a midfield trying to compare all the offerings :S but so far (touch wood) this has been working really for my use case although i've yet to do anything other than offload content and torrents onto it.
