2x1.25kg plates![]()
Grrr sylas didn't read, try again.
Start with 60-70 not 30. Advise is if you consider yourself above beginner level then you should drop to 60ish % of what your able to with for 5 reps. Seeing as you can do 100kg for 10 then 60-70 for 5 would be more then comfortable and use the early sessions to work on your form...
2x1.25kg plates
What are your 1 rep maxes. even bad squats at 140 x10 should equate to something close to 160.
70x5 on bench would be 85ish
do you deadlift?
wat
wat
put it on your head.
I will admit I didn't read your post properly, I am le retard. Skillmister has a good point though, adapt and overcome.
I don't know about 1 rep maxes, I'm guessing 110 if we are talking ATG.
Mhedi is a bit of a ball bag but the routine is sound.Yeah low bar like in the starting strength book. I put it a bit higher for ATG (Ass to Grass).
Also found some sexy little 1.5kg weights in the gym in a dark dark corner nobody goes.
The guy who made this Stronglifts routine actually looks pretty skinny, what's up with that?
http://www.youtube.com/watch?v=rIRtZRZE0lA
Whoa also when he squats his legs buckle out like crazy, and the weight looks too heavy for him. I feel like I'm following a bad routine now??His third rep is terrible looks like the bar is gonna slide off. My friends 180kg squat was 10x smoother than that.
