Need a bit of build help!
another quick one sorry before i finish this tomorrow.
I dont have the correct length screws to mount fans to my rad. will it be ok to run the setup with no fans on the radiator for a few days whilst i source screws? It wont be OC'd or anything just stock.
hey guys
quick pic, im at leak testing now! going to leave it for 5-6 hours and see how it goes.
everything seems to be in the right place and as good as it can be despite numerous small issues!
all finished! just installing windows. the avexir ram is super cool
a question i had was, i had to plug my radiator and case fans into the CPU fan plug on the mobo due to positioning (they run off 1 plug) and now the pc is giving me issues with CPU fan because of this, is there a settings or something I can change so the mobo will just run it as a case fan? I would just plug it ina case fan port but the positions are all bad!
