Need a case for this build
26 Mar 2009
Essex
about £110 to spend
well it depend what sort of image you like, you can either look at an antec 902 which has great cooling for any OC'ing you might do, but is a bit flashy or if you want something a bit more subdued then have a look at one of the Lian Li's
I would go with the Antec 300, generaly regarded as one of, if not the best lower range case, loads of room and great cooling from 2 optional front fans and the two rear exaust fans. Just grab two fans for £20 and your golden. The case itself is only £50.
Other than that the Antec 900 or 900-2.
lamps the 4890s have dropped in price. :D
Get the Asus 'voltage tweek' one for only £203.
Oh, and get the Silverstone Fortress.
