I bough a computer from a pc shop it called a Phillips Flat linewhats a phillips case?
£80 will get you an 8800gt
Will it go into my case?Yep £80 for an 8800GT or HD3870. Just got my 3870 for £70 very happy with it.
So what do you call them then ? thinking about phoning overclockers and ordering it from there over the phonephillips flatline paperweight maybe? sorry, only joking. you'll need to measure the space available in your case, most, if not all modern GFX cards are quite wide, and some can be quite long.
but chances are his power supply wont run itDONT get the 4670, just get the 3870. Its better and same price.
Sorry it is a LS1600DO you have a model for the PC? without knowing which case it uses its hard to know if it will fit.
edit* just read the post properly
doh![]()
Will this be any good http://www.overclockers.co.uk/showp...B DDR2 TV-Out/DVI/HDMI (PCI-Express) - RetailYes you will need a low profile card which limits your options
