Need advice please?!
as it says on the link :-
Memory upgrade information
Dual channel memory architecture
Four 240-pin DDR2 DIMM sockets
Supported DIMM types:
DDR2-800
DDR2-667
Non-ECC memory only, unbuffered
Supports 2 GB DDR2 DIMMs
Supports 8 GB on 64 bit PCs
Supports 4 GB* on 32 bit PCs
What are you planning to use the system for?
Also just double check the power supply. I know it says 300W in the link but it's worth confirming. (Remove side panel of the case and have a look at the sticker on the PSU). Also have a look to see how many 6pin PCI-E connectors the power supply has.
The main limiting factor is likely to be the space inside this case. Get a rule and see how much space you have a new card.
I am going to use it for gaming. Games like Call of Duty 4, Skyrim, Day Z . Not too fussed about having it maxed out, just no FPS lag. Willing to spend up to £150 on a new GPU.
Also, can the 8GB RAM be DDR3 or won't my computer support DDR3?
