- 18 Jul 2009
Fair enough then, no reason not to use works then for me.
You hit that with no tuning?
Well here's my first attempt after tuning. I'm now going to try with default tuning and yes it's Works Converted for me
<snip>
Default Tuning
T-1 Slight dab on the brakes - Drop to 5th
T-2 No brakes - Drop to 5th
T-3/4 Slight dab on the brakes - Drop to 4th (from 5/6th)
T-5 No brakes - Taken in 5th
T-6 Change up to 6th as soon as you start going downhill
T-7 Last corner. When the racing line turns red drop to 5th - No need to brake
Merlin, you are one aggressive driver, that's not a bad thing. You need to know when & how to use this aggression to your advantage.I feel you CK61938, same for me. It's obviously possible to get much lower as these other guys have shown, but I'm at a complete loss as to how. I'm driving this, well, 'almost' perfect, yet still can't even get 1:23 , let alone 1:22.I've uploaded a video of me doing a complete set of laps, perhaps someone can give me pointers.
My driving gets smoothest by the last lap
Watching your vid you haven't a problem with your speed, if anything you could brake later, turn-in later. This is your aggressive side which is good. Don't alter this too much.Thanks for the advice nikaz. In a nutshell then, you're saying I need to slow myself down a bit more at corners really and make sure I take them more smoothly and progressively to avoid steering correction?
Once in a corner be smooth & progressive yes!!
It may feel slower but your lap time will come down. It feels slower because your input is less.
One more thing. You may go slower (lap time) whilst you adapt your cornering. DO NOT be put off by this. This is normal.
True, but, it does demonstrate how nikaz takes corners more smoothly than me. Also, I just noticed he's holding about 112mph fairly constantly at the long right hand curve from 0:25 seconds, whereas I dropped from 116mph to around 95mph going into the curve, so I'm presuming I should be able to hold a faster speed at that curve. Or maybe not if the renault doesn't grip as well, I dunno.![]()
Thanks a lot nikaz for watching the vid and offering your wisdomYeah, I have to admit, I've often been surprised (on other courses not just this one) where I've seen my laptime reduced when I've actually gone SLOWER into corners or just generally driven more relaxed. The difficulty though is trying to drive a course slower, sometimes cars seem to grip better at faster speeds. I'll need to try and slow myself down a bit on this one initially to try and perfect these corners. I just found a video of you with another car on willow springs GP. It gives me a better idea of how you approached it.
<snip>
