I reckon I could do a 51 with a bit of luck but Nikaz has been a bit quiet for my liking - I get the feeling he is waiting in the wings with some crazy fast time... also not seen Lewdogga yet this week
I haven't changed anything, other than messing about with the gears to make them a touch shorter, I have no idea what all the other stuff does and usually just copy Nikaz' settings
No... I immediately fiddle with them..
usually I start by dropping tyre pressure to around 32something.. and upping the downforce. This gives me tones of grip
Then straight to the gearbox.. I aim to tune it so all lines are parallel, and then just move the overall ratio slider.
Next step is to add/reduce toe and camber depending the tracks geometry..
and then suspension.
Usually I first twitch fast rebound, then slow rebound, and last the fast/slow bump.
As I learn the track.. I remove downforce to gain time and soften/stiffen springs and antiroll..
Usually Nikaz's setup is exactly the opposite from me.. but again.. the point is to set it according to your driving style.
