Need good cpu cooler
tbh doubt you will notice much difference if any between the true spirit 120/140, CM hyper 612S and CM hyper 212 evo, which one is better seems to vary from review to review
The difference between the 412s and 612s is the size of the heatsink they both have the same fan. The 212s evo has a better fan which actually makes it better than the 412s and 612s in some of the reviews I have seen.
I think the advantage of the 212s evo is it has PWM so the fan speed can change.
612 > 212
TS140 > TS120
Reviews that have this the other way round are clearly wrong. The 612 is much bigger than the 212 and is in a totally different league performance wise and in terms of noise. Similarly the TS140 is larger and has 2 more heat pipes over the TS120.
OP, get the 612S. Look at the results in my sig and the review on that site. Although I don't have the results of the TS140 on there, I have tested it and they match the Archon's result for comparison.
