The i7 is 2600 when I add all of it up it still says £388 the catch could potentially be that there is no PSU but there not overly expensive so if the worst comes to worst and it’s got too little watts or is not included at all then I can buy another one.
Full specs
AeroCool Cyber-X Advance with Red LED + 2x RED LED Fans on the front and a 120mm black fan for optimal cooling and silent operation.
CPU:
Intel Core i7-2600 4x 3.40GHz Base // 3.80GHz Turbo
Intel Core i5-2400 4x 3.10GHz Base // 3.40GHz Turbo
Motherboard:
We use high-quality and reliable motherboards from Intel, equipped with 1x DVi + VGA for dual monitor configuration WITHOUT a graphics card. 6x USB 2.0 + Fron Panel USB and SD Card Reader connected to the Motherboard.
Memory:
8GB: Recommended minimum for Gaming and larger mixed, workloads. Enough for running most AAA games and for most productivity workloads.
16GB: Highly recommended if you like to keep 20+ browser windows open and working with memory hungry productivity related applications, such as Photoshop which can easily use 8GB of system memory even with light-medium workloads.
Graphics Cards Options:*
On-Board Graphics: Ideal for very basic gaming but for gaming we always recommend a dedicated graphics card. Dual screen capable, perfect for Office, browsing and other general tasks.
nVidia GT710 2GB GPU: Entry level GPU for basic gaming on low and medium quality settings, we recommend 1360x768 or 1600x900 resolution maximum.
nVidia GTX1650 4GB GDDR5 Memory: Strong midrange card for 900p or 1080p gaming. Depending on games, it is capable to deliver 60fps on medium to highest depending on the title and resolution.
*Please make sure you choose the right option for you. If you are unsure about your requirements, please feel free to contact us, we are here to help.
Storage options:
SSD: a small SSD goes a long way with everyday tasks. Even a 120GB SSD for the system drive will significantly speed up the system speed and reduces loading times. We recommend a 240GB SSD in order fo you to load your programs and games on it on the long run.
HDD: Everyone needs storage, a 1TB drive can store an estimated of: 16,660 hours of digital music / 320,000 digital photos / 1,000 hours of digital video / 250 DVD-quality movies.
