Need help checking a Build Please
19 Feb 2010
Uni: Loughborough
Much better (and cheaper).. ;)
- I opted for the K version CPU, it can be overclocked if needed and is the same price. :D
- The mobo you picked is on pre-order, this Gigabyte is just as good if not better.
- RAM is a touch expensive, the below kit (buy 2x) is £20 less.
- Wouldn't ever touch the OcUK branded PSUs (no offense OcUK). This Corsair is much nicer.
EDIT: What is this rig going to be used for? If it is just gaming, then get the i5-3570K instead for £80 less. The difference in performance (when gaming) will not be noticeable.
YOUR BASKET
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £239.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £81.98
1 x Corsair Enthusiast Series TX550M High Performance 550W '80 Plus Bronze' Modular Power Supply (CP-9020001-UK) £59.99
2 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £29.99 (£59.98)
Total : £453.94 (includes shipping : £10.00).
I read on these forums that OcUK PSU's aren't anything to write home about, apparently.
Consider a different (branded, e.g. OCZ, Antec, Corsair etc.) PSU perhaps.
Plus you won't really need a 750w PSU unless you have some serious GPU's or other hardware to run in the system.
