- 1 Dec 2003
Hey
I currently have two 120 gig Samsung SATA’s. (it’s the spinpoint range, nice and quiet
) one is a backup of the other (all mainly music/image files) Well they are full now and I’m looking for a new backup solution.
I don’t like to keep both hdd’s running at the same time and only connect the backup drive once a month to update it. I just update it manually. Is there a program that if I connected the backup drive it would automatically backup all the changes?
For my new backup drive I would like at least 250gig and again I only want to run/power it up once a month to update.
1. I was considering buying an internal HDD and then putting this in a mobile rack (usb) so it can be turned on/off conveniently (probably the cheaper option). 2. or I was considering buying an external hdd.
Any advise would be appreciated. How do you backup?
ta
) one is a backup of the other (all mainly music/image files) Well they are full now and I’m looking for a new backup solution.I don’t like to keep both hdd’s running at the same time and only connect the backup drive once a month to update it. I just update it manually. Is there a program that if I connected the backup drive it would automatically backup all the changes?
ta
