My only concern so far was that the DAC I want to get has only RCA outputs and the Equator has XLR and TRS connecters so theres no way to get a balanced single is there with those connections?
No there isn't, but I really wouldn't worry about it. Balanced cables are all about eliminating noise, particularly over long distances [which is why they're used in studio/live engineering]; there's no difference in the 'information' bit of the audio signal. For the distance between your DAC and the speakers, a balanced output wouldn't make any perceptible difference.
To be honest, I've only gone for balanced XLRs because a) my DAC has those outputs, and b) it reminds me of my sound engineering days
As I said, the RF noise I heard when testing my D5s was almost certainly down to the onboard sound chip's poor shielding, not the connection to the monitors. An outboard DAC, due to it being shielded and not surrounded by other microelectronics, won't get this interference.
Ultimately, unbalanced outs from a DAC will be totally fine
How do they sound compared to none Coaxial monitors and speakers as there quite expensive but from what iv read give the best sound in that price range and even better than monitors much more expensive. especially the midrange sound.
I've got no non-coaxials to A/B them against [they're going to be replacing an old Acoustic Energy Aego P5 5.1 system], and I don't have any recent experience with monitors in studios to compare, sorry. All I know is that from my brief test, the soundstage was wide and precise, and there was the clarity and neutrality in the mids that I was expecting from all that I've read. I didn't mention it earlier, because I thought it was taken as read that these are excellent in this area.
For what it's worth, I've been a long-time fan of Aego 5.1 / 2.1 systems, and was thinking of keeping mine to use alongside the D5s, but as soon as I switched back to the Aegos I knew I'd never use them once my D5s were properly hooked up and running. The difference was surprising; really noticable.
Also do you think the Audioengine D1 Dac would be a good choice?
No experience of it, but it seems to review well.
If you don't need the headphone amp, then the little Epiphany Audio E-DAC that Overclockers sell might be worth a look and save you a few quid. I bought one a couple of weeks ago for my old Headroom headphone amp, and I can't fault it.
Would you also be able to do a pic for me of your desk... id love to see how big they look on there.
Aye, will do once they're properly set up and on their isolation stands.
Last thing: it's best NOT to use headphone out to connect to powered monitors. You run the risk of impedance mismatches [potentially damaging], which seems silly when there'll be a perfectly good set of line-level RCA outs available too
