Need help clocking core2 6600
15 Jan 2006
my spec is mobo=P5W DH Deluxe, 8800GTS 640, 2GiG ram, stock cooler.
hi guys can some give me some advice on clocking my setup pls i know i can use the software option but i would prefer to use the bios so any tips and instrution would be very welcome.
Hal
Personally I found that mobo got a little too hot for my likings, I'd recommend stripping it down and replacing their useless thermal pads with AS5 (and the CPU if you haven't).
I lost all my settings for running it at 3.6ghz (though you wouldn't get that out of a default cooler) so hopefully someone more knowledgable than myself will help you.
Though thats a 25% Overclock :p.
Thanx for the tips the idle temp did drop to 26c after a few mins seems ok just ran 3dmark06 with no trouble may do a bit more reading on clocking cus there are a lot of things in the bios with this board i don't know wether to leave them on auto or disable. thanx again for your help.
These are the settings I used to run at 3.6ghz.
However, these were with:
Intel C2D e6600
G.Skill 2gb HZ
ASUS P5W DH Deluxe
Titan Amanda TEC Cooler
CPU Frequency: 400
DRAM Frequency: DDR2 800Mhz
Performance Mode: Standard
PCI Express: 105
PCI Clock Syncronization: 33.33mhz
Memory 2.15
CPU 1.55
FSB Termination Voltage: 1.4
MCH Chipset Voltage: 1.65
ICH Chipset Voltage: 1.2
_*CPU Configuration*_
Microcode Updation: Enabled
Max CPUID Value Limit: Disabled
Execute Disable Function: Disabled
Enhanced C1 Control: Disabled
CPU Internal Thermal Control: Disabled
Virtualization Technology: Disabled
Intel Speedstep Tech Disabled
_*Advanced Chipset Setting*_
Configure DRAM Timing by SPD: Disabled
DRAM CAS# Latency: 4 Clocks
DRAM RAS# Precharge: 4 Clocks
DRAM RAS# to CAS# Delay: 4 Clocks
DRAM RAS# Activate to Precharge: 12 Clocks
DRAM Write Recovery Time: 4 Clocks
DRAM ECC Mode: Disabled
Hyperpath 3: Disabled
DRAM Throttling Threshold: Disabled
All credit for these go to fornowagain.
