need help confirming final spec
16 Nov 2005
Newry, Northern ireland
ok i'm ordering my first pc ( that belongs 100% to me :D ) this weekend and i just need to double check everything in here is fine:
Shopping Cart (Prices in British Pounds)
REFERENCE DESCRIPTION QUANTITY PRICE COST REMOVE
MB-062-GI Gigabyte GA_965P_DS4 (Socket 775) PCI-Express DDR2 Motherboard (MB-062-GI)
£104.99 £104.99
CD-078-SA Samsung SH-S182D 18x18 DVD±RW ReWriter (Black) (CD-078-SA)
£16.99 £16.99
CD-002-SA Samsung SH-D162 DVD-ROM (Black) - OEM (CD-002-SA)
£11.99 £11.99
KB-019-SK Saitek Eclipse 2 Illuminated Keyboard - Blue/Red/Purple (KB-019-SK)
£29.99 £29.99
KB-084-LG Logitech MX 400 Performance Laser Mouse - Retail (KB-084-LG)
£24.99 £24.99
MY-058-GL GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
£164.99 £164.99
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£14.99 £14.99
CA-065-AN Antec Nine Hundred Ultimate Gaming case (CA-065-AN)
£63.99 £63.99
GX-112-SP Sapphire ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-112-SP)
£209.99 £209.99
CA-008-TG Tagan TG530-U15 530W ATX2.01 Easycon SLi Compliant Modular Silent PSU (CA-008-TG)
£62.99 £62.99
CP-126-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£114.99 £114.99
HD-023-HI Hitachi Deskstar T7K500 NCQ 250GB SATA-II 8MB Cache - OEM (0A33423) (HD-023-HI)
£46.99 £46.99
Subtotal £867.88
VAT £151.88
Total £1,019.76
my budget is £880 ( excluding vat.)
will everything work ok in that spec? also, if people have any ideas on what i can replace with something cheaper without losing much performance, although i'm determined to keep that case. that 1900xt is also just for reference, i'm getting one off a mate for £175 ( 512meg version). anyone have any ideas? i was thinking maybe get a 1900GTO instead and clock it?
any feedback would be nice , thanks in advance.
thanks. ok i'm now tempted to just buy a lower spec graphics card and buy something later after the 8800 series gets released, i just want to game at 1024x768 with no AA or AF, would a 7600GT do the trick in the meantime? or would a 7900GS be wiser?
ok, ive waited ages and no-one has helpd yet, i'm just wondering is a 1900xt overkill? would a 7900GS be wiser because i'l only be playing my games at 1280x1024 max, and i'l be quite happy to play oblivion at medium quality. does that seem ok then? and does anybody have any idea of what parts of the spec i can change to save a few bucks without hurting performance too much?
tis a good spec, from the sounds of your usage(light gaming) i would be tempted to maybe, get a cheaper less elaborate motherboard and a mid range graphics card... X1950pro, or maybe X1800XT if you can get hold of one... tis worth spending the money on a X1800 then a 7600gt...
